Well-known member
- Joined
- Oct 2, 2011
- Messages
- 5,143
- Reaction score
- 92
- C Dory Year
- 2009
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- UWH25301J809
- Vessel Name
- C-Traveler
This is what I've accomplished so far. Next will be test fitting the frames in the boat, then installing the screen into the frame.
I purchased the frame channel from Menards. I made the round corners from some hard nylon plastic (starboard?) that I planed down to the appropriate thickness, and then cut out with my band saw. First I made a pattern from the window. These will be for the aft port window, and head window right across from it.
If everything fits properly, I'll install the screens. At the corners, since there is no channel for the screen rope to go into, I'll hot glue the screen directly to the corner piece.
