Tug
Active member
- Joined
- Jun 22, 2007
- Messages
- 1,003
- Reaction score
- 6
- C Dory Year
- 1985
- C Dory Model
- 22 Angler
- Hull Identification Number
- DOR22241H585
- Vessel Name
- Drifter
AFi STD Wiper Kit Windshield Frame Mount ..Product # 32000 , 12 Volt Standard Motor,80 Degree Sweep, 11 inch Blade, 6-3/4 to 10 1/2 Adjustable Arm..........I installed the StarBoard Electrical Wiper today.It went together easily except that it doesn't work.hmmm! I wired it for regular operation verses self-park operation. Wire from the negative wiper motor connection to the negative bus connection..Red wire from the switch connection on the wiper motor to the # 1 toggle switch connection----red wire from # 2 toggle switch connection to the fuse and to the positive bus connection. The electric motor also has a positive connector but it saws that it is not used when wired for regular operation.I seem to have wired it correctly but it is dead, i tried another toggle switch but still no go.Note..with a tester there is power to the positive wire side of the toggle switch as should be----when i turn the toggle switch on there is no power from the toggle switch to the wiper motor switch connector when i touch it with the electrical tester....With the toggle switch open there should be power running from the positive wire thru the toggle switch up to the wiper motor..any what do i do next ideas..Thanks Tug
