Well-known member
- Joined
- Oct 2, 2011
- Messages
- 5,079
- Reaction score
- 34
- C Dory Year
- 2009
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- UWH25301J809
- Vessel Name
- C-Traveler
The photo above is at the front port side of my 2009 Yamaha F150 4-stroke outboard. The fuse panel and wiring terminals are behind a plastic shield. My outboard has an alternate charging system, in addition to the regular system from the alternator. Don’t ask me how it works, I don’t have a clue. The two red wires at the wiring terminal appear to go to the alternator and to the alternate charging lead. The two large red fuses in the fuse block at the left, are 50 amp fuses, and the top one appears to be for the alternate charging system.
So here’s the deal. The normal alternator appears to be putting out about 14.5 volts at the batteries, at the second or lower red fuse in the left fuse block, and at the red wire’s terminal at that wiring terminal on the right. (When the batteries are somewhat discharged, then the voltage drops to about 13.5 volts.) However, the top fuse, and the alternate charging lead at the battery is showing about 15.5 volts when the battery is connected. It drops back down to just a bit over 12 volts when I disconnect the battery. I am reading voltage from my Vectron Battery Monitor, the Digital Engine gauge and a separate VOM, with the engine at idle, and also at around 1000 rpm.
The alternate charging lead is hooked to my starting battery and unless I trip the breaker near the battery in that lead, that battery is always getting charged thru the alternate system. That would be battery 2. My house battery is battery 1. If I have the batteries isolated, ie, battery switch to battery 1, then I’m seeing that 15.5 vts on my starting battery. If I go to both, or battery 2 (thereby bringing both the regular and alternate systems into battery 2) it seems to even the voltage out back to about 14.5 volts if the batteries are charged, or 13.x when they are being charged. If I select battery 1, the house battery, then I will see the normal voltage of 14.5 on it, but battery 2 with the alternate charging system is back at about 15.5 volts.
I believe 15 + volts is probably a bit too high for my standard lead acid batteries. I spoke with a mechanic last week, and he felt it was probably a bad regulator/rectifier. Well I just replaced that today with a brand new one, and I’m getting the same readings, so thinking then that the voltage regulator/rectifier is good. But still concerned about the higher voltage output on the alternate charging side.
Does anyone have experience with Yamaha’s alternate charging system, know anything about it, or if voltage of 15.5 volts is good for my lead acid starting battery? I am leaning towards just removing the alternate charging system by leaving the CB tripped at battery 2, and using my 1,2,both battery switch for charging my start battery. Colby
