Tom,
This shows what you need for the check.
Vessel Safety Check (VSC) Required Equipment List. Pre vessel exam check off list
NUMBERING-- Proper spacing, 3” contrasting block letters/numbers ONLY. Must have a space or – between letters and numbers displayed on forward half of the vessel. Ex. WN 2696 LR or WN-2696-LR
REGISTRATION or DOCUMENTATION—Current papers must be on board.
NAVIGATION LIGHTS—Must be operational and show proper configuration for size and type on vessel.
SOUND PRODUCING DEVICE—Horn/whistle if > 65 ft (20M) . Horn/whistle and bell if <65 ft.
LIFE JACKETS—One wearable in serviceable condition for each occupant, minimum of 2. Boats >16ft also required to have one type IV (Throwable)
FIRE EXTINQUISHER—Minimum for size & type of boat. Halon, FE241, and CO2 require current inspection tag (inspected within 1 year) Dry Chemical no tag required for most boats.
VISUAL DISTRESS SIGNALS (VDS) INTERNATIONAL—Minimum of 3unexpired day/night combination flares, or other approved signals.
VENTILATION—For closed compartments with potential for explosive vapors, and an ignition source. Installed blower must work. Warning decal posted at helm. (Not required for diesel engines)
BACKFIRE FLAME ARRESTOR—Gasoline engines. Approved type, tight installation and clean. Not required for diesel or outboards.
FUEL SYSTEM—Tanks secure. Over 7 gal. capacity are considered permanent and must be grounded and vented. Hoses in good condition, no leaks.
ALTERNATE PROPULSION—Vessels under 16 ft, paddle or oar.
DEWATERING DEVICE—Electric bilge pumps must work, plus extra manual bailer, (bucket or hand pump).
OVERALL VESSEL CONDITION—Bilge and equipment space clean, well maintained. Not overloaded or overpowered, and no automotive electrical parts.
ELECTRICAL SYSTEMS—Batteries secure, terminals covered, well organized, proper fuses/circuit breakers.
GALLEY/HEATING SYSTEMS—Secure system, proper tank installation, No flammable material nearby. New style propane tank valves.
STATE REQUIREMENTS—complies with all state safety requirements per WA Boaters Guide.
MARINE SANITATION DEVICE—Approved device, inadvertant overboard discharge sealed at “Y” valve or closed seacock.
PLACARDS—MARPOL TRASH and OIL POLLUTION required on vessels <26 ft. Written TRASH PLAN for vessels <39.4 ft. Properly posted.
NAV RULES—Vessels >12M (39.4 ft) are required to have a copy of USCG Nav Rules on board.
CARBON MONOXIDE WARNING LABEL-All power boats. Must be posted so visible to all occupants.
