onemorebythesea
- Joined
- Dec 25, 2006
- Messages
- 3
- Reaction score
- 0
Transom is cracked.
Moisture reading in transom is off the charts... indicates the damage is more than just cosmetic.
Note that most boat photos look shiny and 'well-maintainted' in a wide-shot. Unless you see well-photographed close-ups, don't believe what you see in an ad on the web. It would be nice, though, for a seller to be honest about the condition of his boat.
My opinion is that the boat has taken a beating, run hard and left wet, and has suffered as a consequence.
Other clues that this boat is not a great deal include- corrosion, Expired Reg: Boat was not used in 2006, Chip in bottom on stb. chine, Moisture in Transom, Oil Filter (maybe Tightened w/ wrench?), Cracked Deck, Tide lines in bilge, Loose electrical board, refrigerator loose in frame, Unsecured Hose to thru-hull, Antenna loose, Crack in deck Port fwd, Crack in roof.
I, for one, wouldn't want to have to rebuild a soft transom... but all boats are projects for someone.
I have added a few photos in the "For Sale section". Hope that helps.
[/img]
[/img]
