jkidd
Active member
- Joined
- Oct 23, 2006
- Messages
- 1,685
- Reaction score
- 10
- C Dory Year
- 2007
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- CDo22670C707
- Vessel Name
- Voyager
Sunflower":3f26sray said:Jody looks like you got a great set up. I did the same with the jack stands two in back one on keel in front, but I had to leave the trailer underneath and work around it. It was a pain. Good luck with the project I am sure it will turn out great.
Water Bill":oletjf25 said:Looking good Jody. I am impressed!
pcg":3137cr4a said:I'm curious why some want to raise the bottom paint line several inches. Why?
ssobol":m0xk0z8t said:pcg":m0xk0z8t said:I'm curious why some want to raise the bottom paint line several inches. Why?
Depending on the load on the boat, the actual waterline can be a number of inches higher than the colored part of the lower hull (boot stripe) particularly at the stern. Raising the paint line protects the parts of the hull that are in the water. The factory should raise the color line of the lower hull a bit in the build process.
