krc
- Joined
- Nov 6, 2017
- Messages
- 121
- Reaction score
- 0
- C Dory Year
- 2006
- C Dory Model
- 25 Cruiser
A couple of weekends ago I was out fishing and had a stuck anchor. I was able to release but noticed that the windlass pull was "not as strong". I figured that in the process of working the anchor loose with the boat and pulling it up the battery drained out. But, windlass was still not operating "full strength" when I got back to the dock. Ex: I can let the chain out on the dock but then it just isn't strong enough to pull the anchor itself off the dock and it just stops. No circuit blows.
So, battery tester for the 690MCA load check was good. Voltage is like 12.8. I was concerned that the charger was not working or the vsr (BEP) wasn't switching. Anchor is tied to house battery. Voltage drop when pulling up and "stopping" was around 11v. I brought down my own charger but it only ran for maybe 10 minutes then said FUL.
So I wired up a new circuit to windlass switch at the helm and wired into the starboard start battery - that had the same result. Very difficult to pull up and eventually stops.
The wiring from the switch to the motor looks good - nothing obvious. I was really thinking this was a battery issue but it is a one year old battery, the load tests look good, the voltage drop at load looks minimal, and same issue when using the start battery.
So, what is next? Are these motors repairable? I have to think this is the next step. I have a doc with the manuals saying "lewmar" but no part # I can get to- just a warranty. Boat is a 2006 and I think original to the boat. Motor housing has no info other than warning stickers.
What is the way to pull these motors out? I assume I can do this without pullig off the pull on the top deck? So there are bolts that seem to bolt through the top deck, then other bolts that attach the motor to the "housing" or frame. I assume I pull this and the motor will drop out?
I will put the pic in the album.
With a motor that I suspect is so old, do you just replace the motor or does whole windlass need replacing?
I do note that it is also hard to pull in manually with the sprocket, but that could be me just doing something wrong. I have to pull that lever out on the top side of the windless to get it winding up manually (lifting the anchor).
Ideas?
Ideas?
