gary allen
I was very disappointed to discover some rot in the balsa core of my new C-Dory.
I bought my 22 Cruiser in August of 2004. I have kept it in a slip at a marina here in Bodega Bay, on the northern California coast. Although the boat was not covered, the bilge pump was functioning throughout the winter rains, and I cleaned the boat and took it out regularly.
I took the boat out of the slip recently to clean it and prep it for salmon season. As I was checking the tightness of the screws securing the cleats holding the fuel tanks in place, I noticed that the screw on the inside corner of the starboard side (low point on the deck) just spun in place and wouldn't tighten. When I removed the cleat, I found water inside the screw hole, and as I inserted an allen wrench to check the "punkiness" of the wood, I found rotted wood going back at least 3/4 of an inch.
Securing those cleats with screws in a balsa cored boat seems to be a major design flaw. I'm not quite sure what to do at this point. Should I call C-Dory and check on the hull warranty? Check with the dealer? Repair it myself with marine grade epoxy? And if I do, how long do I have to let it air out and dry? With salmon season coming in two weeks and with rains on the way, I feel some pressure to take care of this problem right away or at least do a temporary fix...
Somewhat disillusioned,
Gary
Gary
