Swee Pea
- Joined
- Nov 2, 2003
- Messages
- 406
- Reaction score
- 0
- C Dory Year
- 2004
- C Dory Model
- 22 Cruiser
- Vessel Name
- Swee Pea
Couldn't figure out why my Rule Mate 1100 Bilge Pump would not work. Checked the fuse in the lazarette (10 amp) and it was blown. Every time I replaced it with a 10 amp, it blew. Tried to trace wires, no visual breaks. Called a local mechanic who came by. Replaced the fuse with a 20 amp. Still not working, but did not blow the fuse. He used a tester to see the pump was getting juice. Removed the pump and the impeller not turning. A piece of debris way up behind the impeller - dug it out, impeller turned. Then BAM, like a firecracker, blew the top off the bilge pump. Stink! Burned up bilge pump. :amgry
Gotta get another pump. (No Duh!) Wonder what the cause was? I asked about that 20 amp fuse, but the mechanic said that was not the problem. :roll:
I'm a dummy, I don't know.
Ordered a new pump. Maybe some of you all's insight will help edumacate me a little, before we burn another one up. :cry
Swee Pea
Swee Pea
