Bilge Pump Blew Up - Literally
Swee Pea
Nov 2, 2003
410
2
2004
Swee Pea
Couldn't figure out why my Rule Mate 1100 Bilge Pump would not work. Checked the fuse in the lazarette (10 amp) and it was blown. Every time I replaced it with a 10 amp, it blew. Tried to trace wires, no visual breaks. Called a local mechanic who came by. Replaced the fuse with a 20 amp. Still not working, but did not blow the fuse. He used a tester to see the pump was getting juice. Removed the pump and the impeller not turning. A piece of debris way up behind the impeller - dug it out, impeller turned. Then BAM, like a firecracker, blew the top off the bilge pump. Stink! Burned up bilge pump. :amgry
Gotta get another pump. (No Duh!) Wonder what the cause was? I asked about that 20 amp fuse, but the mechanic said that was not the problem. :roll:
I'm a dummy, I don't know. :oops: Ordered a new pump. Maybe some of you all's insight will help edumacate me a little, before we burn another one up. :cry
Swee Pea
John-
The problem was most probably that the current into the motor had heated up the armature at the brushes, melted the solder, and jammed the armature copper contacts against the brushes. The armature was at that point not round and could not turn.
This happened either because of the initial blockage, or when the larger fuse was added, and the current left on.
He might have said the larger fuse was not the problem to avoid the responsibility factor. How long was the current left on with the 20 amp fuse in place?
Fuses are there and in a specified size for at least two reasons, first to protect the component fused from overloads, and secondly, to prevent electrically induced fires.
Next time try to test the pump to see if the impeller will turn (along with the motor) before going to a larger fuse, and then only use the larger fuse for a few seconds, understanding that the larger fuse can cause additional damage itself.
Joe. :teeth :thup
John,
I don't know if the 20amp fuse was the cause of the problem, but I think you should go back and kick your boat mechanic square in the a$$. Let him walk around with his butt between his shoulder blades for a while.
Putting oversize fuses and circuit breakers in is not safe, and could conceivably melt some wiring...
Steve
Your boat mechanic should be referred to as your former boat mechanic. Only use the fuses the device is specified for. A stalled or jammed motor draws a whole lot of current as there is no back emf to oppose the current flow. More than likely if the 10 amp fuse is the correct fuse for that motor, then no damage was caused when the 10 amp fuse blew. Can't say the same with using a 20 amp one.
-Mark
The big problem is not the pump, as it was probably toast already. The problem is the wiring from the source to the pump, that may have been stressed by the overload. It should be examined for evidence of over heating.
That's what I kinda thought. I will put back a 10 amp and see what happens.
Sometimes I think that I am the least qualified person to own a boat; I am not a mechanic, an electrician, or a certified Captain. I like my C-Dory because it is a simple boat. Hah! :roll: Just look at that nest of wires behind the wire cover in the berth area. :shock: Add the fuel systems, complex motors, steering cables, ELECTRONICS, Wallas stove, electrical system, charging system, etc., etc. I feel like I am at the mercy of others :cry ... and get bad advice from the local talent in my area. :evil:
But I wouldn't trade or sell my boat for anything, nor trade the friendships of this site for the so-called local experts. I need to develop some patience and give you guys some time to "bail me out". :wink:
Thanks guys (and gals)
Swee Pea
John,
It's one thing to be ignorant, as you are about some things. It is another to have been exposed to the right way to do things and then be stupid enough to ignore that knowledge and do what your "mechanic" did.
It is hard to fix stupid. Not difficult to fix ignorance. You'll pick stuff up incrementally as you go along. That's all anybody ever does.
And, in the morning, we all put our pants on: one ... leg ... at ... a ... time!
You might find it useful to pick up a copy of Nigel Calder's Boatowner's Mechanical and Electrical Manual and keep it handy for the next time something goes bozo. No need to try to digest that tome without a context or a need, but if you have it handy, you will absorb stuff as you need it. Link: http://www.amazon.com/Boatowners-Mechan ... 007009618X
Your "ex-mechanic" teaches a lesson I learned years ago in electronics school: never fuse a circuit with a fuse larger than the origional. The fuses primary function is to protect the wiring. You should absolutly inspect the wire to make sure it is still intact. You will be looking for obvios signs like melted or burned insulation. Hopefully, you have no more hassel than replacing your pump, If you do find your pump circuit wires are damaged be sure to check adjacent wiring for damage also, Good Luck.
Last week I went to my boat and heard the bilge pump running when I stepped aboard. I opened the hatch and saw the bilge was dry but the pump continued to run. The pump, a Rule-Mate 1100 gph had one of those sealed automatic water sensor switch units on it. The pump continued to run even after I lifted it from the base. Long story short, as afternoon thunderstorms were forcast, I cut the wires and not being able to find a replacement locally, replaced it with the Rule-Mate 1100 from the cabin, this one having a movable floating type switch on it. I'll replace the cabin pump with one I ordered on line, with a floating switch.
I guess the sealed water sensors cause the pump to become a throw away once they go bad. Anyone else have problems with this type of automatic switch or have a preference to other automatic bilge pumps and switches?
Rich, Central NY
richnkay":8yd2bhru said:
<Some clipped>
Rich, Central NY
Rich-
The "automatic" Rule pumps have several faults:
1. They cycle on and off every few minutes, searching for water in the bilge. (They do this rather than have a float. If the impeller encounters water, the extra amperage draw needed by the motor to turn is read by the "brain" inside the top of the pump unit to be water in the bilge, and they run until the amperage goes down (the impeller hits air, and spins freely).
2. They drive people crazy when they're trying to sleep, cycling on and off, on and off, on and off, ad infinitum!
3. They waste a lot of battery power unnecessarily. No problem if you're on shore power with a charger, but moored up to a buoy w/o replacement charging........='s dead batteries !
4. They malfunction a lot, just like yours! And the replacement cost is $120! For and 1100 gallon pump that costs $40 without the troublesome "brain"!
I had one, and had the same problem. I cut the top of the pump housing open carefully, did a complete lobotomy of the brain (integrated circuit and board), wired it directly in the "on" position, and glued it back together, watertight. Now I had the basic $40 pump, and could control it with an external float switch and/or a manual on-off switch.
Sometimes old school is better!
Joe. :lol: :thup
I had the same problem with the pump under the step in my 25 designed to pump the cabin. One day it started running while I was there. It does have an internal float switch as it is wired with 3 wires. One hot to the battery, one to the switch at the helm, and ground. Not know which to cut to stop it, I elected to do the ground until I could determine whether to cut the brown wire or brown/white wire. I now have a manually switched pump. I think I will add an external float switch sometime in the near future.
Joe,
Thanks for your comments, I kept the pump, hate throwing away things that even kinda work. I think I will take it apart for a look and if I don't mess it up too badly during the disection re-work it and keep it around as an emergency spare.
Rich
I replaced the annoying "every two minute" bilge pump with a Rule 1100 Automatic (built in float) and it worked for more than three years without a glitch. I am sure your diagnosis is correct: debris clogging the impeller and overheating/too much resistance/ weakening the pump. A 20 amp fuse helped fry the pump. But that thing blew like a firecracker.
I will install a new pump with a 10 amp fuse and see if I can figure out a better way to keep debris out. Wiring seems fine.
Thanks for all your input.
Swee Pea
P.S. Astoria Dave: I prefer the term "uninformed" rather than ignorant. I hear your point.
Dang, I have the same pump. Been procrastinating about purchasing a backup other than the old hand pump, guess I’ll be making a visit to WM. We were stuck up in a cove last weekend while a storm moved in off the Gulf of Alaska, 36hr on the hook. The rain was relentlessly and we had left our side curtains in the truck. The bilge pump was coming on a lot and was thinking it would really be a drag if I had to hand pump the cockpit periodically throughout the night.
Sometimes if the outboard is running I can’t hear the pump when it is trying to pump and nothing is coming out, that’s how these things get burned up as others have said. Best to make sure things are working well before bedding down for the night.
Most bilge pumps are labeled with the current draw and the recommended fuse size (usually a couple of amps higher). The idea is that if the pump seizes, the increase in current draw will blow the fuse; but if the fuse is too high a value (and 10amps sounds high), the pump will overheat and possibly catch on fire. Additionally, if the wire size feeding the pump is too small for the run (and most are), the resistance of the line can defeat the safety of the fuse with the overload. Generally, I've seen the fuse recommended to be around 6-8 amps. I would wonder if a 10 amp fuse might be too high to blow if the motor seizes.
Tim & Dave Kinghorn
New Rule 1100 pump in, 10 amp fuse replaced. Everything good as new. I am looking to get some stainless or aluminum screen to line the mid-bilge area to keep some of the debris away from the pump.
Joe. I found my original "auto-every-two-second" Rule pumps. Will you describe the "lobotomy" operation to deactivate the auto-on-every-two-second part of the brain? Can't the wire that activates the brain just be cut and sealed off or is there more to it? (Which wire to cut - brown or brown with white?)
Thanks again to all for your input and for sharing your experiences.
Swee Pea
The on-line site for Rule Bilge Pumps states that the Rule 1100 pulls about 3.8 amps and should be fused at 6 amps. The problem with a larger fuse develops when the the pumps jams. When a bilge pump starts up, there is an initial higher current flow. Until the pump gets up to speed and develops a voltage back pressure, the pumps pulls more than the 3.8 amps at running speed. If it jams and you have a higher amp fuse than the recommended 6 amps, the fuse won't blow; the pump will overheat and melt or possibly catch on fire.
See the Hull and Fittings Forum, Where did the water come from? Another case of a pump getting clogged and melting down.
Tim & Dave Kinghorn
Swee Pea":3tb5laxu said:
<Some clipped>
Swee Pea
John-
It's been awhile, but as I remember, the pump just has two wires, both of which have to be left attached for the pump to run.
The trick is to cut just deep enough in a circle about 1-1/2" down from the top of the pump to cut through the white plastic cover.
Lift the cover off, and note the printed circuit "Brain" of the unit.
Cut it out, and connect the ingoing and outgoing wires to it together. Solder them or use a good solderless connector and cover the metal with insulation, like liquid electrical tape.Test it out, it should run wheen the power is connected to the two feeder wires, and shut off when you disconnect.
Now go back and put the cover back on the unit and seal it up. I believe I used a good deal of silicone rubber to make a joint, then wrapped it with fiberglass packing tape once it dried/set up hard. The extra tape is for structural strength.
Don't put the tape on too soon as you want the acetic acid vapors to escape, rather than be trapped inside the pump where they will corrode the motor.
JB Weld may well be a better and stronger sealer, and may not need the fiberglass packing tape for structural reinforcement.
Good Luck with your "lobotomy" !
Joe. :lol: :thup
The aft bilge pump on Journey On also seized. I discovered this when the circuit breaker kept blowing. When I took the pump off the mount, the impeller was stuck, which bolws the breaker/fuse for sure.
I don't know what the C-22 has for circuit protection, but the C-25 has circuit breakers on the DC switch panel for the aft pump. And I have no intention of wiring around that.
The original pump is/was a Rule 1100, just as mentioned above. It had an integral float so that the pump only came on when there was water present. I ordered a new Rule-Mate 1100 A and the darn thing now (according to the brochure) senses the presence of water by capacitance. The claim is that it will not pump oil and no mention of cyclic operation is made.
My question is, if you got this far, does anyone have experience with this pump?
