Bilge pump running down batteries. When I bought my 22 I saw a wire coming off the battery with the fuse pulled. The seller said that was for the auto bilge pump (Rule 1100) but it ran down the battery. I could not comprehend that the factory would put in something that ran the battery down, but he was right. I have the boat in the water so sort of want a bilge pump that does it's job. I ran the motor a week ago but now it does not have enough juice to start.
The manual says the pump comes on for about 2 seconds every 2 minutes. This means it comes on over 5,000 times a week, seems overkill when there is no water.
Have any of you changed out your bilge pump to a float pump or what would you recommend doing.
Thanks!
Thanks!
