Socrateur
- Joined
- Feb 16, 2006
- Messages
- 244
- Reaction score
- 0
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Vessel Name
- Sea Skipper
Which was it when oldgrowth made C-Voyager?
The former, otherwise it wouldn't have turned out so well.
Sea Wolf":15a9kpg4 said:The PV pipes on the trailer have holes drilled every 20" or so from front to back. There are 20 numbered ribs from front to back made up of 1/2" diameter smaller PVC pipes with 1/2" dowels inserted into the ends that fit into the holes in the bigger pipes. They form a "covered wagon" like structure over the boat to hold a cover for storage that is above all the sharp points and won't tear from the wind, rain, etc. The ones in the front are shorter than the ones in the middle, etc. Bungees hold the cover ends down over the ribs to the trailer frame.
Pandion":2ff44etz said:Sea Wolf":2ff44etz said:The PV pipes on the trailer have holes drilled every 20" or so from front to back. There are 20 numbered ribs from front to back made up of 1/2" diameter smaller PVC pipes with 1/2" dowels inserted into the ends that fit into the holes in the bigger pipes. They form a "covered wagon" like structure over the boat to hold a cover for storage that is above all the sharp points and won't tear from the wind, rain, etc. The ones in the front are shorter than the ones in the middle, etc. Bungees hold the cover ends down over the ribs to the trailer frame.
Joe, do you happen to have a photo of your boat cover in action?
ospreysails":2x5qdxza said:Has anyone considered using a loading ramp such as this one sold at tractor supply for a boarding ramp?
http://www.tractorsupply.com//ProductDi ... _vc=-10005
It folds, is light, and is reasonable at $40. Should be easy to strap on the cabin roof.
ospreysails":1eujq2e6 said:Sea Wolf: Your comments Are all valid ones. Let me explain how and why I plan to use the ramp. It's not so much for me to use as it is my crew. I did join the old geezers club ( turned 70 ) last month. But I don't have any trouble yet, jumping off the boat to secure the ramp for the crew. The wife doesn't mind getting her feet wet, either. My biggest reason for the ramp is getting my 60# dog ashore.
I'm thinking that by using a buddy line off the front and securing a stern anchor. I should be able to get to shore and secure the ramp by mounting one end on the swim platform with quick pins and the other end on shore. Now I should be able to assist the crew on ' walking the plank '. If it doesn't work maybe I'll just use the ramp to load the dog into my John Deere Gator.
Pandion":2re0iztf said:Haven't found a 5-step bow ladder, but the 3- and 4-step models are here:
http://www.wholesalemarine.com/windline ... 35133.html
bmacpiper":1wxa6axo said:Hey there Joe,
I am about to install the same ladder as yours on Big Blue. I am thinking about moving it about 1" to stern, so it overlaps just a hair with the bow rail stanchion. Given your experience with yours, do you like that it floats under the bow rail, or do you wish you could strap it hard to the stanchion/railing?
Best and talk soon,
Ben
