Well-known member
- Joined
- Oct 2, 2011
- Messages
- 5,143
- Reaction score
- 92
- C Dory Year
- 2009
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- UWH25301J809
- Vessel Name
- C-Traveler
Hi Dave, I may have overstated the mileage. I'll let you do the math. Last year I took the boat/trailer out to the San Juans. This year I took it out to Lake Powell, and then up to the North Channel. (I live just outside of Madison Wi). It's made numerous trips to Door County & Lake Michigan, been to Lake Cumberland, St. Louis, Dubuque several times, Northern Wisconsin a few times. And countless local trips. All on that same set of brakes seen in the pictures. As for technology. Won't argue your point on being cheap. I can replace the entire brake plate assembly (everything you see in one photo, not including the drum) for $40. Times 4 is a set of brakes for a tandem axle trailer under $200. (That's for Dexters. I can do cheaper at Amazon, but then you get what you pay for...) I didn't price drums, but I believe they are around $30. How much are discs again? And SS? As for safety, the purely electric have worked flawlessly for me, not only on this boat trailer, but two other boats/trailers I owned in the past. True, I'm a fresh water sailor, so I'm just going to leave it at that. Now if I had a lot more money, I probably wouldn't own the CD-22, and chances are what I would own, wouldn't need a trailer!
JMHO!
My point is that there is nothing wrong with all electric brakes, if maintained, (at least in fresh water use) and they are the least expensive of brakes available. I also agree stainless steel discs are great. But at an added expense, that may or may not be justified. I'm simply sharing my experience with the electric brakes, for anyone else that might be considering them as an cost effective alternative to the more expensive EOH or Disc. And from what I hear, it sounds like the EOH are showing to have occasional issue with the pump. Either EOH or Electric will always be superior to surge! A perfect brake to me would be electric disc! (Why not, we have electric trim tabs?) Colby
P.s. Kind of like our boats. There are other boats out there that offer much better performance than the 22' C-Dory. But we like our boats because they work well (very well) for how we intend to use them. I look at this argument on brakes the same way. For me, the all electric brakes work well (very well) for how I use them!
