Hi Tom,
I don't know how other "big" motors are, but my Yamaha 80 doesn't even have a place for the "quick connect" type of clip like my Honda 8 (and smaller motors of my youth) have. On the 80, the fuel line goes from the bulb, in through a sort of round disc with a number of holes in it (each hole has a wire or a hose running through it, to separate and protect them), and then on to the internal/Yamaha fuel filter. I know the exact route because I replaced that line (it was cracked out near the bulb, but since it is all one length of hose, I replaced the whole thing).
So, I can't just "unclip" it to run it dry. It is carbureted.
I was thinking that when I get off the lake I would run both engines dry and then drain the carbs, but I don't know that I have an easy way to run the Yamaha dry (that is if I can't cut the fuel supply). True, I could turn the C-Dory selector to "off," but then I still have the Racor after that. Just thought someone might know a certain type of valve that was suited to in line "floppy section of hose" use, and/or have another trick. It's new territory to me.
I will stop in Page and put some "pure" gas in the tanks, but then I don't have an easy way to run the engines after that. Maybe I'll have to dunk in a pond somewhere....
Actually, I have not decided yet whether to tow the boat southeast for the winter, or perhaps leave it in Page and come back for it. Either way, it would be at least weeks before I used it again, if not months. I had all of my carbs totally rebuilt when I bought the boat (it had been sitting, so I knew I was going to be doing that) and I'm not eager to have that done again anytime soon if I can help it.
