pcg
- Joined
- Aug 31, 2018
- Messages
- 470
- Reaction score
- 15
- C Dory Year
- 1999
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- DOR22866J999
Yesterday I attended a Victron Energy Training Session. Most attendees were professional system installers (RVs or marine), but there were a few DIYers like myself in attendance. I learned from some of the installers that ABYC now (or will soon – I didn’t clarify that) requires that any LiFePO4 (LFP) battery on board a boat must have an EXTERNAL battery management system (with the exception of cell balancing circuitry).
I did a little research to verify this and came across this article … https://marinehowto.com/lifepo4-batteries-on-boats/. The author identifies himself as an active member of the American Boat and Yacht Council (ABYC) Li-ion Battery committee that is working on the safety standards for Li-Ion batteries. I won’t go into details about how this came about, the article does that, but apparently it has something to do with drop-in (complete internal BMS) LFP batteries designed to power street lights in a foreign country, that have internal contactors (used to disconnect charge and load currents) that are not adequate to handle current loads sometimes seen on boats. Some of these batteries have been repackaged and sold in the US under other names. I did verify that Victron Energy is NOT one of these. It is unfortunate though, as it is clear from Victron's data sheet, that their Li Superpack (internal BMS) battery can safely handle all currents that the battery would normally see on a small boat. They, and Battleborn, appear to be getting swept out with the bad guys.
If you’re curious about what a BMS for LFP batteries is required to do, here’s a summary of what I’ve learned. I found this topic a bit confusing at first and it took me awhile to feel like I somewhat get it, but if any of you have something to add or correct please do…
BMS requirements:
1) Cell balancing. All batteries that contain multiple cells assembled into one package (12v, 24V, etc.) have circuitry inside that enables cell balancing.
2) Load disconnect in the case of under voltage.
3) Charge current disconnect in the case of over voltage, high temperature, or low temperature.
The above are the fundamental requirements for a BMS. However, if the LFP is going to be on a boat, be aware that there are two additional requirements that may soon be (or are now) recommended by the ABYC:
1) There must be an alarm that warns the user before the BMS performs a load disconnect. This is to give the boat operator time to make adjustments and preparations for the disconnect.
2) The load disconnect and charge disconnect functions of the BMS must be performed external to the battery package. In other words, the battery package cannot be a drop-in battery – a battery with the complete BMS built into the battery package.
Prior to yesterday, I was planning on using a LFP with an internal BMS battery from Battleborn, Victron Energy, or Renogy, but am now planning on using a Victron Energy Smart Li battery, which does cell balancing internally, but the remainder of the BMS (load and charge disconnect) is done externally. Victron makes an array of products to do this, as there are a number of different ways it can be done, depending on what other components are in the specific design.
BMS requirements:
