Donald Tyson
Member
- Joined
- Jul 24, 2023
- Messages
- 688
- Reaction score
- 11
Wow, maybe I'll stick with my single axle surge brakes.
Salmon Fisher":3l66mbk4 said:Colby,
I would call Etrailer and ask if those Kodiak calipers cross reference with yours. Or you can look it up on that website, there are lots of questions for each product and Etrailer publishes both questions and answers.
Patrick
KevinMc":1nop10h9 said:Just a thought about the deteriorating sliding pin cover boots.If the boot stays on,all well and good,I think the boot is there to resist the caliper pin from rusting and gumming up while the pads are wearing and restricting the inward motion of the moving part of the caliper.It is disconcerting to find the boots deteriorating before the pins have reached their maximum inward travel at which time you would have to replace the pads.I think your idea of heat is part of the problem but I would consider not replacing the boots after 500 /1000 miles,only lightly oil the exposed pin heads each time you service the trailer.
By that time the bronze/brass pin bushings would have worn enough to allow a dirty pin to slide without binding.P.S.I suspect the trailer brakes are not as long lived as auto brakes and can be expected to wear out much sooner,In Florida with salt water that is about every two years.
I'm not certain of the purpose of the rubber bushing you mentioned, but to me it looks like a dust cap.
P.s. to help folks out with Peter's numbers, in case you weren't sure. 3500 kms = 2174 miles. 25c-35c = 77F-95F.
