It's those damn disc brake calipers again
Colbysmith.All kidding aside,your 25 footer (near 7K LBS loaded) puts a lot of wear and tear on those Dexter units,seems like you are very attentive to your maintenance schedule and still having no luck.I would trash them an go with Kodiak or another HD brand.. I would hate to loose a citizen of Doryland.
Just saying.
Ok, I think I may have found/fabricated a fix for my brake calipers.
This is my post on Facebook:
For my mechanic friends. As I have complained about before, the rubber boots that my boat trailer brake caliper slider pins work through, tend to disintegrate after longer travel. I suspect they are simply burning up from the heat generated by the disc brakes. I have yet to get a reply back from Dexter. I don't care to buy more expensive calipers that have steel bushings, so decided to see if I could make or buy bushings to fit in place of the rubber ones. Lo and behold, I found some bronze bushings that appear to fit. 3/4" x 1/2" and 1 1/8" long. From Amazon: https://www.amazon.com/dp/B00MND8R5W...
After sanding the outside of the bushings lightly, and cleaning the inside of the caliper bracket where they go, I was able to press them in with a vice. The slider pin seems to go thru them easy enough, with very little free play. For now, they are open, that is no dust boot on them, but I feel that dust can get in from the brake side, so no use trying to cover the back side. I'm hoping these work, but does anyone see any problems that I've overlooked? I plan to install these brake calipers on one axle and see how they do, before replacing the other two on the other axle.
If you go to the first or second page of this thread, you can see photos of the rubber boots, and how they start to disintegrate.
Here are some photos of the bronze bushings in place of the rubber boots.
A mechanic friend of mine suggested placing some kind of rubber cap or something over the bronze bushing to keep dust and grit out. I may have to do a little more fabrication to place some form of protection around both ends of the bronze bushing. But for now, I'll just see how they work without any dust seal. Colby
Great idea! I can't think of any downside. I would not add any rubber caps that could trap moisture. It's amazing what can be found on Amazon. It used to be that a machine shop would have been required for that type of part.
-Jeff-
Colby, I was just doing some research on electric brakes for boat trailers. I started trailering 30 years ago and that was a "no-no" at the time because the brakes were not up to being submerged, especially in corrosive salt water. Thus, I have always used hydraulic disc brakes. From what I read it looks like modern e brakes are more waterproof if you take certain precautions. The folks at e-trailer suggest that all connections are made using heat shrink fittings with hot melt inside (marine grade) and they also suggest that you unplug the trailer before going down the ramp. If you do go with electric please let us know how that works out.
Thanks Jeff. I rethought the caps to seal the slider pin as well. Unless I'm sealing both ends, I think it's better just to leave them open so any water or sand can flush out. There is very little freeplay between the pins and bushing anyway. I may still have to grease the pins every so often. So far, on my trip up here to the Apostle Islands (350 miles), my bronze bushings seemed to work well. If everything goes good on the way home, I'll install bronze on the remaining axle. I'll know more after the next two months with a trip to the Erie and another one out west.
Hi Tom,
Don't get me started on the nay sayers of electric brakes. Up until this trailer with the EOH, only because Loadrite would not install electric brakes, I ran them on past boat trailers. (Also fabricated an internal fresh water flush system using the small hydroponic sprayers.) They work great! Of course I rarely launch in salt water. But I don't think the problem there is the electricity, but the materials used in drum brakes. And that doesn't matter rather they are electric or hydraulic. The issue really is the material. SS or Iron...The electric magnet itself is sealed where the wires go in, and rather it's for brakes or trailer lights, your wiring connections should be sealed. I still unplug my pigtail when launching the boat. Don't know if that's even necessary anymore. Just a habit. But I do use the sealing connectors when I repair or rewire. And my LED trailer lights are sealed at the light. Colby
If interested, check out my youtube channel to see a video of my installing these bronze bushings. Colby
Follow up. Just thought I'd follow up with my changeover from the rubber bushings to bronze. So far the brakes seem to be working fine. I did have a brake pad go missing on my last trip to Pirates Cove Marina on the Erie Canal, but replaced it before returning home. (Pad appears to have broken off the backing plate.) The real test will be next month traveling out west and back, over the Rockies. Colby
Well, the bronze bushings still seem to be doing fine. Even going through the Rockies. However, I did have another brake pad fail on the way to Lake Powell. After launching, I found one of the brake pads missing with just the metal backing plate still there. And while doing my annual maintenance after getting back home, while pulling all the trailer wheels to check and adjust the wheel bearings and change the hub oil, I checked all the brakes and found most of the pads in bad condition. So am I just getting cheap a$$ brake pads, or is there more going on? One of the pads was broke in half, with the one half detached from the metal backing plate, but still in position. Almost all the others, except for one or two, where in bad shape. All of these had plenty of material left on them, but in crappy condition. I'm really getting frustrated with these electric over hydraulic disc brakes!
Colby, I sure understand your frustration with the brakes, as I know you’re good about preventive maintenance. Perhaps the sourcing or supply chain of the pads are ending up with you getting inferior pads. I now have 68,000 miles on my present electric over hydraulic brakes with only one replacement of pads so far & no problems with brakes or bearings in those miles. The same with my previous trailer with 40,000 miles before replacing it. It could be, I have less problems due to truck being a one ton with engine braking & the trailer load being lighter, so much less brake use. Maybe with the 1/2 ton truck & a much heavier trailer load your brakes on the trailer are getting worked to hard or just as mentioned before inferior pads. I use Kodiak pads.
I have experienced brake pads separating from the backing plate after just one season when using non stainless backing plates and metalic pads. I switched to the stainless version with ceramic pads and no more problems. Yours look to have a lot of corrosion both on the backing plate and the pads. If the pads are metalic, the metalic particals corrode and lock up on the rotor while parked for a period of time. If the backing plate corrodes the glue fails and the pad gets ripped off the backing plate. It does not matter how well you rinse off the salt water, once they have been in the salt the corrosion process has begun.
Another thought (in addition to the issues of corrosion): Since you have electric over hydraulic, I wonder if your brake controller is set too high? Have you checked your brake controller? I don't know what you have, but on mine, I can adjust how much power is applied to the trailer brakes. If too much power is applied, the trailer brakes are also trying to stop the truck, putting a lot of extra pressure on the trailer brakes.
I don't see corrosion on the pads or calipers. Could just be the photo lighting. Mystery Girl Bill reminded me he has had to replace pads half a dozen times as well. Also Pacific Trailer inexpensive ones. I think those are the same ones I have rebuilt the calipers with. So I'm thinking it's more to do with cheap parts rather than braking issues. The brakes are set on medium on my Ford F150 electric brake setting. I can feel when they engage, on hard stops, which isn't often. Otherwise, I don't think they are set to high. My brother asked about heat, but I have a TPMS now and feel I would see hotter temps on that if it was a heat problem or dragging brakes. Or I would notice the heat while doing walk arounds and touching the hubs. So at this point, I think Jay has nailed it with inferior sourcing. Now that my caliper slider pin boot problems seem to have been resolved with the bronze bushings, I may have to spend a little more money on the pads. I just got some from Michigan Wheel (thru Amazon) that are a little more expensive. They are on one of the axles now, so I'll have to see how they hold up next season. Colby
Regarding brake pads, it would be interesting to run a set of Kodiak pads on one axle and the new ones you just purchased on the other axle. Given the good results that Jay has had with Kodiak, it might be a worthwhile experiment, Colby.
