Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,793
- Reaction score
- 140
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
Tom is correct, one of the problems was that the "load test" voltage was tested at the windlass--not at the battery, when using the windlass as a load. If the voltage had been tested at the battery, it would have shown no drop in voltage. (and the windlass would not have engaged). The high resistance (not enough conductivity) was from the wiring from the battery to the ground (as I read the results)
That $20 battery load tester either from Amazon or Harbor freight would have saved a lot of trips to Wallyworld, and a sore back!
Incidentally CCA (cold cranking amps) does not relate directly to Amp hours. The Amp hours is what we want to follow in our house batteries.
