Byrdman
- Joined
- Nov 6, 2003
- Messages
- 3,329
- Reaction score
- 0
- Vessel Name
- " ? " After Rename Ceremony
Well, every now and then ya just see something that sends your mind over the edge thinking about the endless possibilities... Well, below is a pic of one of those type items. I will give the "uneducated/novis" version.... post the picture, and then let my Brother Mike go from there on a later post.
Bottom line, this "T" fitting is just one of the many "basic" fittings, elbows, couplings, caps.... etc.. that can be assembled/disassembled in seconds...with it's little handy dandy "snap ring" gizmo (the orange thing in the pic).. It just snaps over the pipe used (many options), pushes in the compresion fitting gizmo,,,, let go... and presto... you have a new compresion fitting....that can be taken apart just as easy and quickly...
Now... just think... In the size of a small shoe box or tupperware container,,, you could store your shower sysetem for your boat, pop it out, pop it together, use it, take it apart, stow it again till next time.
No more dedicating a bunch of room just for a shower and it's needed plumbing. Just snap in place a few fittings, run a flex hose back to the swim platform, soap up, shower, rinse, leave the soap and gunk in the water...not in your boat.... and no thru hull needed for the drain.
Hot or cold water pipe options, snaps into/out of place each fitting over 1000 times each!!... Now... they do not have the big "M" on them, so you can still get'm pretty cheap...
Is this neat or what???
Sorry for the poor focus on the pic... could be the light, could be me shaking, could be the caffene....could be batteries about to go out cause the little red light is flashing and I can not find my battery charger yet and that is the best picture your gonna get right now...
