thataway":kj47q542 said:
All circuits should be fused. For example where I had 200 amps of LiFePO4 battery and only about 2 feet of 00 cable to the inverter/charger, I fused the 00 within 6" of the battery at 300 amps. Be sure and cover all terminals so there is no possibility of stay tool or wire hitting your live cables.
I also fused the charging circuit (30 amp Sterling B to B charger). I fused at the output of the B to B charger, there was already a fuse on the input of the charger. I also put a 30 amp breaker at the input of the wire from the charger to the battery.
I also fuse the 120V AC out of the inverter. Again, you are protecting the boat. The GRFI is protecting the crew.
Although one might say they are "protecting the cable". You are really protecting the boat from a fire.
I do fuse all my circuits, except for the main battery cables. It's my understanding that the code doesn't require them to be fused between the battery and the starter. In fact, I've never seen any boats, or cars, fuse the main cable off the battery. However, all my other circuits on the other side of the main battery switch, or smaller wires I attach at the battery posts, are fused. I believe as long as the main battery cables are protected from chaffing, and are large enough to handle the starter or combined loads on them, fusing them at the battery isn't necessary.
That being said, after some of your comments, and others, I did decide to get some large amperage MRBF type fuse blocks for the inverter battery cable and for the house battery cable that goes over to the main battery switch. I'm going with 125 amps for the inverter, and 200 amps for the main cable over to the main battery switch. I'm not going to fuse the main cable coming off the starter battery. It's a very short cable going to the main battery switch, and this battery is primary the start battery. My hope is that the very few times I use the house battery to start my main outboard, that the 200 amps will hold the current. IF not, I will likely remove that fuse.
I'm kind of thinking / talking this through as I install the inverter. Another change, rather than putting a main battery switch inline for the inverter, I ordered a heavy duty 200 amp relay. I found out that the remote on/off switch for the inverter doesn't do anything more than shut off the output power. The inverter still must be turned on with it's chasis switch, and the digital window still shows input power. I want to be able to completely shut it down when not in use. And without having to go back into the compartment each time to do so. Having the relay on it, will allow me to switch the power to it off and on from the cabin. I plan to use the Macerator switch at my main helm panel, as I no longer have a macerator, so it's an available switch.
I got the Victron shunt remounted and hooked up today. Had to order a new one, as the "phone line" connection on the old one broke off as I was unhooking it. A new PCB board was only $28 at one of the yacht supplies, so not to expensive. I'll give the install a rest over the next few days while I await my Amazon shipments of wire, relay and fuses. And enjoy Christmas! Colby
