I have owned a Ranger 2012 25 SC.
Very heavy to tow and almost 3 times the draft so harder to launch on shallow ramps. The longer trailer needed makes it more of a challenge when maneuvering at gas stations and parking lots. I felt a lot safer towing it when I traded in my 3/4 ton diesel for a 1 ton with an exhaust brake and an automatic leveling air bag towing package.
The Tug is very much a luxury yacht in micro form, extensive teak trim, fore and aft thrusters, available built in generator, solar system, kayak racks, stern mounted dinghy, central heat and air, a high end electronics package, built in cockpit folding seats, BBQ, and cooler plus every othe possible trick thing in the book. If you want it they have it. They have a very good fiberglass layup system the hulls are stout and the interiors have very little condensation, the deep V hull is quiet and never pounds. The solid dark colored gel coat fades badly and is a lot of labor to keep pristine.
The downside for me is I am a DIY guy all the complex systems are carefully hidden from sight behind liners and teak trim. In the diesel ones like mine only the aft part of the engine is accessible through the big cockpit so all the belts, pumps and hoses that need yearly maintenance are accessed through a tiny hatch under the interior step turning 5 minute maintenance jobs into hours of pain and cussing.
They have multiple ACR's, batteries, fuse blocks, the charger, waterheater, thruster and engine fuses and computer all mounted under leaky cockpit sole hatches and I found prone to corrosion issues. Marine Yanmar and Volvo mechanics are far and in between away from the coasts. And unless you are a more than average mechanic yourself you will need the constant maintenance done by a very competant professional. This is normal for new Tug owners who tend to live an upscale lifestyle. The wives love all the interior luxury and all the comforts of home in a small package.
Diesel is not always available on lakes.
They cruise on a semi-plane at between 10 and 15 knots though the high speed cruise has a limited time because the diesels are not continuously rated.
Bottom line if you want a small yacht with every luxury and a lot of wow factor, are ok with the need for a high level of maintenance this could be perfect for you. Even better if you buy one of the newer outboard powered boats.
We bought an older C-dory that was basic so I could build it into the off the dock trailerable cruising bost I wanted. Except for the new outboards I was able to easily replace every system on the boat with new myself. The interior is simple and basic with most systems easily accessible. The balsa coring can have water intrusion problems which are even more of a problem in a freezing climate. If you understand it you can prevent this problem, but have a used boat surveyed. The boats that have aluminum fuel tanks can have tank corrosion. After 05 they have a molded cockpit liner with a large fuel tank floor access molded plate, a cleaner more modern look and no laminated plywood floor leak problems.
It is much lighter, easy to trailer and launch at any ramp. The hull pounds at speed in chop but will easily cruise between 15 and 25 knots (we have a 200 Suzuki) at slightly better economy than the Tug on flat water. Except for a stand up vberth it has the same basic layout as the Tug. Many of these boats are equipped with all the same features as the Tugs except for all the teak and thrusters. It does have more interior condensation. (Ventures have less because of liners, they also have foam coring)
C-dory owners seem to be very practical minded, handy and spend time on their boats traveling extensively with their boats. And note the different vibe on the TugNuts vs. C-brats forum.
For us having had many boats over the years, mostly large sailboats we, in the end prefer our CD 25 over our previous R 25.
