do dawdle
- Joined
- Aug 25, 2012
- Messages
- 17
- Reaction score
- 0
- C Dory Year
- 1985
- C Dory Model
- user_field_choice.c_dory_model_16_Angler
- Vessel Name
- Patsy Lou
I just bought an '85 16' Angler that I am taking to Sportcraft in Portland to have new 40 HP and 5 HP Hondas put on the boat. The 5 HP will be used as a trolling motor (anything bigger will go too fast for my style of fishing.)
On past boats I've had problems with the battery running down when I ran the kicker to troll all day for 8-10 hours or so using the sonar continuously.
My son suggested getting a dual battery system but I think weight and space considerations make two batteries not the best choice.
Of course the 40 HP motor has the standard Honda electrical system per their specs: 22 amp alternator, 17 amp charging power.
There is an optional dealer-installed 3 amp charging system that Honda advertises for the 5HP. I am thinking of getting this added to the 5 HP motor and connecting it to the battery along with the main motor's electrical leads. If I'm thinking correctly, the 3-amp system should keep the battery charged (or at least keep it from running down as fast) while I'm trolling for extended periods and using the sonar all the time, and perhaps a radio as well.
In the past I've ran my big motor several times every few hours to keep the battery charged, but I don't want to run my big motor if I can use the small one for that purpose while I'm fishing.
Would there be any problems associated with having both of these charging systems connected to the battery?
Am I on the right track?
