Catch 22..Kevins Side Mounted Gunnel 20 Gallon Gas Tanks..........i just received a quote for the fabrication of Kevins gas Gunnel Gas Tanks, the price is higher than i would of expected....each tanks is around $ 725.00 and does not include the tanks top and side mounting tabs and brackets , epoxy coating, fuel and vent hoses, taxes and delivery...below is a more details description..Tug
Per your request, we are pleased to quote pricing on fabrication of (2) fuel tanks: As per your spec’s.
SPECIFICATIONS:
§ Includes all necessary fittings - Fill, Vent, Grounding Tab, and Stainless Steel Pick Up Tube
§ Includes upgraded Stainless Steel Electric Tube Type Sending Unit
§ Material = (.125) 1/8” thick Marine Grade Aluminum, T-5052 H32
§ Pressure Tested to 5psi
§ Baffled in accordance with US Coast Guard regulations
§ Labeled in accordance with US Coast Guard regulations
§ Includes one (1) year manufacturer’s warranty after completing 25-Point quality control checklist.
§ Lead time approx. 7 – 10 working days
Estimated Cost: $725.00 each plus any applicable taxes
OPTIONS: Upon Request
□ Plymastic / White Epoxy additional $85.00 each
□ Fully Welded Mounting Tabs / Top Bracket and side mount additional $75.00
□ Installation Supplies – Vent Hose, Add’l. Fittings, Adhesive, Tank Isolation Materials, etc.
□ Delivery / Shipping
□ Material thickness upgrades
□ Cleanouts / Access Ports
□ RUSH Order
Thank you for your interest in SP Sheet Metal Company and the opportunity to quote you. Please do not hesitate to call or e-mail with any questions or concerns.
Thank you kindly,
Diane Holt
446 N. Main St.
Barnegat, NJ 08005
(P)609 698-8800
(F)609 698-8802
http://sptanks.com/
SPECIFICATIONS:
□ RUSH Order
Thank you kindly,
Diane Holt
446 N. Main St.
Barnegat, NJ 08005
(P)609 698-8800
(F)609 698-8802
http://sptanks.com/
