finally finished installing the new steering cable. Probably wouldn't try it again. The opening in the splashwell is too tight and pulling the starboard engine would make it easier, but who has an engine hoist at home. So Had to enlarge the hole, and it was still really difficult. Threading the cable forward was easy. Found out the helm unit was different size than the original and the problems mounted. Ended up having to add spacers to get it to fit. Otherwise it was conflicting with the bulkhead at one corner. So the spacers meant that the keyway was too far forward and wouldn't clear the bezel. So ended trimming the bezel. It is finally done but will spring for the hydraulic if their is a next time. The same corner that caused the trouble also is up against the horn button so will have to isolate that some way. Time to rebundle and tie up all the wires and put stuff back together. What a pain. But at least the helm doesn't have a clunk anymore.
Drained both fuel tanks and started pulling them out of the boat for hose replacements and cleaning/re-sealing and painting. Found cracked vent hoses so I think they could all use replacement at this ten year mark. Darn I love my vacuum pump for moving fuel. So fast...
Greg
I called Wallas and told them that my 95DU stove/heater is not working again... Third time in 2 1/2 years. The tough part is that it cost $40 each way to ship it to the west coast for them to make repairs.
My fondness of this device is quickly sinking.
Started on the berth area foam removal. The boat has a factory hatch in the forwardmost section of the berth for storage but it seems they really made up for that foam loss in the remaining two sections to the sides.
I used a putty knife, huge screwdriver/lever, and drill with a bent bolt in the chuck and a hooked knife. I got about 1/3 of the foam out on one side in an hour. Too much damn work. I am headed to harbor frieght to look for more cutting tool possibilities today. I need some kind of flexible hand saw or an air grinder with a wire wheel. The drill was hard on the wrist.
Greg
Aurelia":2uli6qns said:
...it seems they really made up for that foam loss in the remaining two sections to the sides.
I'm sorry to hear you did not do well on the "foam lottery" :wink: Carpy, who has a 22 of my same year, hardly had any, and I'm hoping my boat was done by the same employee/same day :lol:
I remember Casey had a good "pro tip" in his album for something that worked well. IIRC, it was some sort of drill wheel - nothing expensive or fancy. I had it in mind as something to check back on when I do the project.
Removed the Wallas stove/heater from the boat and packed it for shipment because is will not run. Sadly it cost about $45 to ship it each way to the west coast and this is the 3rd time in 2 years...
What was the problem with your $3K+ Wallas the last 2 times? I've ordered the current model of this beast and would like to know is it's dependable.
Aye.
W B Nod,
I wish it was bullet proof, but so far it has been nothing but a pain in the ___ (you can use most any derogatory word you want in the blank). The good part is that I'm a pro at removal and installation and have yet to shred my skin on the exhaust pipe during the process).
The first time, the problem was that the previous owner of the boat most likely did not use the unit, so it just needed a good tune-up along with a fuel pump.
The second time the CO detector went off and I almost succumbed to the exhaust gases (great alarm as it make a lot of noise). Scan Marine cleaned up the burner and replaced the glow plug.
This time one of the fans is not working properly and the system goes though the entire start cycle, but does not fire. I called Scan Marine and there is not much that I can do aside from sending it back.
I have used this unit maybe 8 hours total and have spent about $430 so far.
I don't know which exact model you are getting or how it compares to the older ones, but there is quite a bit of discussion of them in the archives here, and will give you a good idea of the pros and cons -- at least of the models most used. So you know (because the numbering seems non-intuitive to me), the 95 is the older model (early 2000's) and the 85 is the newer model (later 2000's). These are both the combination two-burner stove/heater that runs on diesel (or substitute), not the kerosene model(s).
Took a break on the foam removal battle and put in the newly painted frames and new windows. The frames were rusting and two of the windows on the bulkhead were cracked.
The berth foam removal is terrible and they really filled mine up with multiple layers poured in. It is adhered top to bottom on all surfaces and the horizons between the layers are tough like a plastic. I have decided to do about 2/3 of the most accessible area and leave a flat wall of foam at the forward edge of the hatches onward. I have completed one side and it took three hours of fighting! I loose a little storage but it is the tapered area and with factory bulkheads separating the bow triangle from the side areas, I really cant get at the pocket very well. So I will leave a little floatation....
http://www.c-brats.com/modules.php?set_ ... _album.php
So for not being here regular for a while I missed that Gregg is the new owner of the 19 R-Matey. Cool Gregg.
Today, I started keeping a New Years Resolution that I tried before but didn't make it. Today I launched in January and had a wonderful day trip. From Port Townsend into Admiralty Inlet, and south past Marrowstone Island down to Matts Matts Bay entrance and then back up through the PT channel past the empty Naval dock and back into Boat Haven. Polished off the nice crujise with a fish and chips dinner at SeaJays.
It was a gorgeous day, comfy in the boat in a T-shirt and my inflatable PFD without the Wallas. Have to say I sure missed the Standard Horizon 2150 and its AIS input, but it was worth the trip.
February will be here soon, and time to do it again.
SleepyC:moon
Just finished up a fuel system refresh. Replaced corroded fuel filter assembly and pulled both fuel tanks to replace all hoses. Inspection found cracked vent hoses due to sharp bends in how the hoses were installed so I decided to do them all and clean out under the tanks while I was at it. all done and back to the foam project. The gunk under the tanks was pretty thick and when I pulled the port tank off the floor it smelled like an outhouse until I got it all scrubbed away.
The cure (I hope) for the sharp bend in the vent line is a longer hose and loop to make the change in direction easier.
That arrangement makes me wonder: if water gets into the vent line, then wouldn't it act something like a sink trap and thus eliminate the venting function (which you are trying to do with a sink trap, but wouldn't want to do with a fuel vent).
I re-did my entire fuel system (tanks, hoses, filter, etc.) last winter/spring, and although the vent lines have easy runs, the port-side fuel fill has a dog-leg (to avoid the lazarette wall) and I don't know how they had the regular hose making that bend without over-stressing the fill neck on the tank (although obviously they did, somehow). Anyway, I went with the "Michelin Man" style Trident hose (#329) that bends easier for the new hose, but that doesn't come in vent type diameters.
I can't tell for sure from the photo, but is that Trident #305 hose you're using? I used some of that for my outboard fuel line (it had a relatively small OD, which I needed to pass the line into the outboard and to the internal fuel pump), but although I had planned to use it for the whole fuel supply system, I didn't like how easily it collapsed in a bend and so I went with Trident #365 instead. It has a slightly larger OD (not an issue except for that one internal Yamaha line), is heavier duty (longer warranty), and -- perhaps this would be of use to you -- has a tighter bend radius than the #305 (if that is what you used and if you want to try to remove the loop). It's a bit counter-intuitive since the hose seems thicker and heavier duty, but, for example, in the 5/16" ID size, the #305 has a 2.5" bend radius, whereas the #365 has a (better) 1.75" bend radius.
Always interesting to read/see what you're doing to your latest C-Dory.
I hear you on the loop being a water trap. I picked that over a more direct run and more pinch problems. The position of the vent is so high and aft that the risk of water in that hose is nill. If anything, I chose the draw it in option over the dump it in. Not enough pressure can build with a water blockage to worry me either. If we ever take water over or across the stern that severely,I will consider blowing into the fill pipe to clear it! But I might be busy swimming.
Greg
The previous owner told me that the autopilot didn't work, so I uninstalled it. Finally got around to checking it out on the bench, and it looked ok. So I spent yesterday reinstalling it in a different location, and checked it out on the lake today and it works great. Christmas came late this year.
New brake actuator, all new brake lines,new idler hubs, all stainless steel kodiak disk brakes, all new trailer wireing & all new led trailer lights. They are indeed a hole in the water but I love her! Vern
Finally finished digging out foam from the berth area and glued in the mounting blocks I need for the new house batteries up there. Now I am ready to start applying the SC#1000 sound proofing/insulating paint all over the place. That foam job was the least fun I have had on a boat.
