CAVU
- Joined
- Nov 2, 2003
- Messages
- 665
- Reaction score
- 0
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
- Vessel Name
- CAVU
Roger,
I just recently had the same problem with quartering waves splashing up into the exhaust pipe and leaking down the side of the hull. I am not sure if the leak is at the hull joint or where the flex pipe is clamped around the fitting. I am going to run a hose stream down the hull above the fitting to see if I can check the hull fitting seal. If that doesn't leak then I will have to use some kind of sealant around the fitting nipple under the hose clamp. I would appreciate any info or tips about how you fix your leak.
