matt_unique
What do other Tomcat owners use for an anchor? I was thinking about the 22 pound Delta Fast-Set anchor. I anchor in mostly rocks or sand.
Dreamer":1xw8xyre said:... You'll need to remove the top roller from the factory installed anchor bracket. I drilled out the bracket and use a 1/2" Pit pin to secure the anchor. The factory pin bent and was hard to remove. The anchor has never failed to set or hold.
McDipple":afzkc7ee said:I am finishing the specs on a TomCat order. On my present boat I use an E-Z Anchor Puller winch and it works very well. There is never a need to go forward to tend to it at all which looks like a major advantage on a TC.
Has anyone used this product or have an opinion?
McDipple":8ilye3q0 said:I am finishing the specs on a TomCat order. On my present boat I use an E-Z Anchor Puller winch and it works very well. There is never a need to go forward to tend to it at all which looks like a major advantage on a TC.
