Wanderer
- Joined
- Aug 29, 2004
- Messages
- 204
- Reaction score
- 0
- C Dory Year
- 2004
- C Dory Model
- 22 Cruiser
- Vessel Name
- Wanderer
Does anyone tow long distances with the short Tahoe? If so, are the results satisfactory? Mine is a 2001 5.3L V8 with the factory installed hitch rated for 5000 lbs and 500 lbs tongue weight. My new CD22 Cruiser has the 90 HP Honda with two Group 31 AGM batteries under the splash well. For my test drive, I had 10 gallons of fuel and 10 gallons of water. Little else on board.
Today I took the test ride on the highway. Between 50 and 70 MPH, the trailer sways when I change lanes or round a curve. When I straighten out, the swaying dies away. When I tow with my 26 foot RV on a Ford E450 chassis, I get no sway. Does the extra wheel base and weight make such a dramatic difference? If so, which is more important?
The trailer is rated 4900 GVW and weighs some 1100 pounds – leaving 3800 pounds for the boat. Load-Rite says the tongue weight should be between 5 and 7% of the boat and trailer weight. So, if boat and trailer weight 4000 lbs my tongue weight should be between 200 and 280 lbs. Mine is 325 lbs.
If the trailer is loaded correctly, will the short Tahoe work? My first trip will be 1300 miles to the Florida Keys.
Thanks for any insights.
George
George
