Active member
- Joined
- Feb 23, 2012
- Messages
- 3,990
- Reaction score
- 10
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
CDory23":f2awylfe said:I'm resurrecting this thread because I started the project today of adding 3 hatches for storage in the V berth similar to what others have done.
It adds a lot of space, plus allows one to see all of the inside of the hull there. I have been happy with the mod on my boat.
CDory23":f2awylfe said:I'm already started in this project and I"m not going to return the hatches, but I would have been just as happy if not happier putting a lip to support plywood which would lay flat instead. ... It would have been cheaper and also easier to move out of the way when you are digging in there for stuff. The hatch can't be moved obviously and has to be hinged up.
The last thing is the main reason I went with the hatches. But it seems that folks who went with hatches are also very happy with the mod (and it's likely easier/quicker). Not that it's hard to do the lips/hatch boards, but it's one of those fiddly epoxy things.
CDory23":f2awylfe said:For the record my 2003 22 classic cruiser is FULL OF FOAM! It is being a real pain to remove. Currently I"m using a saw/knife to cut it and a few different types of crow bars. This is not an easy task. I haven't gotten terribly far in the foam removal process. If anybody knows an easy way to get it out please don't be shy.
My 22 was the same way (2002). Mine was HUGE BLOCKS of expanded polystyrene (the white bead stuff). I think at some point not too long after 2002 they went to injected/expanding foam, so not sure which you have. The blocks were a huge pain to remove, but the plus is that the hull is clean as a whistle as soon as you get them out. One thing that might help you is to know that (at least on my boat), the way they did it was apparently to lay down a grid of 2" masking tape, sticky side up, on the whole V-berth hull. Then they put the huge (did I say HUGE?) blocks on top of it (so they stuck to the tape). THEN they put the v-berth flat (top) on and tabbed it in place. I didn't know about the tape going in, and could not figure out WHY these blocks would not come up :amgry Not that it's a piece of cake anyway, but at least if you know what you are dealing with it's better. I used a 2' aluminum square (the longer leg) to "saw" the foam (I didn't have a long enough saw, and was away from the majority of my tools). There is more here, with gory photos, starting about 3/4 of the way down the page.
http://www.c-brats.com/viewtopic.php?t= ... &start=105
