OK, starting to panic, heading out tomorrow for four days. The water in the plastic tank tasted awful (new plastic taste), so I drained it and refilled it last night. This morning went to drain and refill again (flushing). Opened the faucet and turned on the water pressure breaker, but nothing comes out. I am thinking, OK, the hot water tank has to refill first. I let the pump run for maybe 15 minutes or more, as the Jabsco manual says "self-priming" and "can run dry." There is no spot where you can visually confirm that water is going into the hot water tank (it is empty), but after running the pump, when I tried to put more cold water in the tank, it was full, indicating nothing had been pumped...the C-Dory so-called manual has NO information in it other than manufacturer's manuals for the individual components - nothing about how the systems operate. So I don't know if I am doing something wrong or if some component is not working...any ideas? (I emailed Jeff and Scott early this morning with a request that somebody call me, but I would love to solve this problem without depending on a call back).
